Want to upgrade swaybars on '92 SS...options?
Posted: Sat Oct 21, 2006 1:03 am
by shemoves
Tell me what fits or throw me some links. I'd like to do both the front and rear.
Posted: Sat Oct 21, 2006 1:50 am
by jamal
whiteline parts at PDM-racing.com
I think the biggest you can get is 22mm front 20-24r. So do that. It should work pretty well with stock spring rates or something stiffer, and you can adjust to your liking.
I just bought a 20mm front bar so I'll have 20/18. Then if I get the adjustable rear bar later they'll still be matched up.
Also consider solid endlinks. They make a pretty noticable difference.
Edit: IPD sells a 22mm Impreza front bar for $96 that I think will fit n/a cars. They list the same bar for 93-06 and don't specify wagon or sedan.
Posted: Sat Oct 21, 2006 2:58 am
by scottzg
search.
Posted: Sun Nov 05, 2006 6:22 pm
by spdracr
man, you got the 18mm rear bar.. how much bigger do you wanna go? if you go too big in the rear you car will be so ass happy. I'd upgrade the front and leave the rear alone.
Posted: Mon Nov 06, 2006 5:20 am
by shemoves
I did not know that. Perhaps I'll just go 22 up front and some slightly stiffer suspension. I really don't like body roll. Jamal, any confirmation if IDP's bar fits the SS?
Posted: Mon Nov 06, 2006 6:51 am
by jamal
I think it is best to replace both if you can. The important thing is to not have too much of a difference either way. The front also needs to be a bit stiffer overall due to the weight distribution. If you make the rear super stiff with a huge bar you kind of throw things off and handling doesn't improve. As to what you should get, 22mm front 20-24 rear makes sense to me as a reasonable increase. 18->22mm is a
123% increase in stiffness.
I didn't realize you had an SS even though it was in the title. In that case, any GC turbo or WRX wagon front swaybar should fit, and even maybe
STi bars, which gives you a lot more options up front. IPD's bar is for n/a Subarus and won't work.
In the rear I think you are stuck with early Legacy specific bars such as the whiteline adjustable. I have heard of people cutting out the bump in the spare tire well to fit other [bigger] bars.
So if you really want to you could get swaybars in like the 27mm range. That would probably be a bit much unless you're seriously tracking or auto-xing the car.
Posted: Mon Nov 06, 2006 7:03 am
by spdracr
just go and get an IPD adjustable rearsway bar if you want bigger in the back. any pre 99 legacy bar will work on your SS. i have a rearsway from a 98 legacy GT wagon on my 92 sedan. 89-99 legacy all the same in the rear sway dept.
Posted: Mon Nov 06, 2006 7:27 am
by shemoves
perhaps 20 rear/22 front. I think I'll try to find a used WRX wagon front bar (maybe Cusco or something) on NASIOC and perhaps an IPD for the rear. How's that sound?
Posted: Mon Nov 06, 2006 8:09 am
by jamal
That would be good but I would recommend getting the adjustable rear bar so you can play with it to see what you like and also could go to a bigger front bar later and keep things balanced. Even or slightly bigger in the front is good. A lot of people seem to think a huge rear bar will make things better but it doesn't really. Basically instead of increasing overall grip by giving the tires a better contact patch you're just decreasing it in the rear.
After all the suspension work I've done, know what I really want? To get rid of these RE92s for a nice sticky, stiff, summer tire (but that will wait until after ski season). If you're not on good tires already you should get some if you want to take advantage of better suspension. Also, are you still on stock struts and springs?
Posted: Mon Nov 06, 2006 5:12 pm
by shemoves
Yah, the RE92s really do suck. Right now the car is on stock struts/springs. I would like to upgrade, but I do not want to lose any ride height as I am going to be running larger-than-stock wheels. I'll likely just get a good all-season tire...I've been looking at the Pirelli Pzero M+S, among others.
Posted: Mon Nov 06, 2006 7:29 pm
by ultrasonic
I'm using the 20mm whiteline front bar. I wish I had the 22mm, or even larger. The front bar makes a huge difference... go large on the front!
Posted: Tue Nov 07, 2006 5:28 pm
by shemoves
ultrasonic wrote:I'm using the 20mm whiteline front bar. I wish I had the 22mm, or even larger. The front bar makes a huge difference... go large on the front!
Good to know, I definitely will then. Is there any need to upgrade the endlinks?
Posted: Wed Nov 08, 2006 5:00 am
by jamal
edit != quote.
my set up
Posted: Tue Nov 14, 2006 6:13 pm
by siouxbe
usco adjustable rear with Whiteline brackets
Whiteline 20mm front
Posted: Wed Nov 15, 2006 6:19 am
by ultrasonic
shemoves wrote:ultrasonic wrote:I'm using the 20mm whiteline front bar. I wish I had the 22mm, or even larger. The front bar makes a huge difference... go large on the front!
I know that when I replaced the rear links on my Impreza I could feel the difference. I have aftermarket links both front and rear on my Legacy. Certainly worth doing, in my opinion.
Posted: Wed Nov 15, 2006 7:45 am
by jamal
I have the kartboy links and they definitely made a big difference. $180 for the set is actually less than OEM replacement links. If you have an adjustable rear bar you might want to consider Helix or Whiteline links instead though. The Kartboys are a bit shorter and some people have and problems with the links hitting the lateral links with bars set on full soft.
For now I have the suspension setup I want so I'm going to look into taking out compliance with stiffer bushings. Right now I'm trying to get urethane swaybar bushings, and I'll probably do control arm and lateral link bushings fairly soon.
