Tranny wont go into gears
Posted: Mon Oct 30, 2006 5:37 am
Ok so I was driving home yesterday after a trip to the beach and all of the sudden my tranny wouldn’t let me shift into any of my gears. It did let it go into 4th with alot of resistance and then I could shift down threw all the gears to get to 1st. Its acting like the clutch is not disengaging. As if I’m taking it out of gear but the clutch is not releasing. I checked the tranny fluid and it was WAY over filled. I don’t know if that would cause this I don’t think it should, if anything I would just see it causing a leak some where but not making me tranny stop working. So if anyone has any ideas on what i can do to fix this cause I’m stumped. But I looked at the shifter linkage everything looked fine. I have really loose bushing but I don’t see that causing this problem. So any help is greatfully appreciated.
