WRX front swaybar will it fits?
Posted: Fri Nov 17, 2006 7:46 am
by ej22t
Hi All,
Friend of mine who just replace another upgraded front swaybar on his 02 WRX. He just sell me his OEM swaybar for very low price and I just wanna know will it fits to a 92 Legacy turbo with GC8 Aluminum front lower control arm and GC8 STi front swaybar link?
Thanks for all reply!
Ben
Posted: Fri Nov 17, 2006 8:20 am
by jamal
it should be pretty close.
Posted: Sat Nov 18, 2006 6:11 am
Is his 02 WRX a sedan or wagon?
Posted: Sat Nov 18, 2006 4:45 pm
by ej22t
He has a Sedan!
Will it able to fits?
BTW, what size of the WRX one compair to the Legacy turbo one?
Ben
Posted: Sun Nov 19, 2006 5:53 am
by jamal
wrx is 20mm which is 53% stiffer than the stock 18mm bar. The Impreza sedan bar is wider than your bar but I think the endlink mounting points on those control arms are a bit farther out.
Posted: Mon Nov 20, 2006 12:01 am
by ej22t
Hi Jamal, is that mean it will not fits to a 92 turbo sedan?
I needs to know its fits or not before I buy it!
Thanks for more info!
Ben
Posted: Mon Nov 20, 2006 4:22 am
by entirelyturbo
Will it fit directly? No.
Will it fit with GC control arms? Not sure. I dunno if the swaybar mounts differently to the control arms, or if the track is the same as Jamal said, or if GC control arms will fit your car without changing the front bushing.
Posted: Mon Nov 20, 2006 6:54 pm
You can probably make it to fit, but I haven't put one on myself, so use that info at your own risk.
Posted: Mon Nov 20, 2006 7:14 pm
by entirelyturbo
I just checked and the GC control arms are the same as ours.
So the swaybar will NOT mount to the GC control arms.
If you want a GD swaybar to fit, you will have to use GD control arms, and you'll have to swap the front bushing in the GD control arms to the GC ones.
Or leave the GD control arms alone and swap to a GD crossmember.
My personal advice, find a swaybar off a BC/BJ Legacy with air ride, they had 19mm front swaybars, as opposed to all the others that had 18mm front swaybars.
Posted: Mon Nov 20, 2006 11:33 pm
by jamal
WRX wagons have 20mm front swaybars I think. They should fit fine.
Posted: Tue Nov 21, 2006 3:16 am
by ej22t
Thanks all of your guys info, that means I have to find a WRX wagon front swaybar for direct fits to our BC chass!!???
Ben
