Which one is the best O2 sensor?
Posted: Wed Nov 22, 2006 4:51 am
by ej22t
Hi all, just found out the CEL code that shows my O2 is gone and now I have 3 options from the local parts shop!
The shop that I asked has 2 different brand O2 instock and 1 they have to order!
The 2 they have are NTK 24524 and Bosch 13255 both are OEM replace parts for 92 Legacy turbo.
The other one that they have to order is the Walker 250-24000.
Please gives me some more info on those 3 o2 sensor above and which one should I got for my car and make it run back to normal!
Thanks!
Ben
Posted: Wed Nov 22, 2006 6:00 am
by Bheinen74
The O2 sensor for the NA is usally cheaper, and it is the same, except the wire is a little bit longer on it, making it an easier install.
Ask them the price difference between the Turbo sensor and the non-turbo sensor, then tell them to get you the non-turbo.
they both work, but why not save some easy money,
saves you much $$$
thanks
Posted: Wed Nov 22, 2006 6:27 am
by ej22t
Thanks and will ask tomorrow for sure!!!
(^v^)
Ben
