Fun stuff in the mail!
Posted: Sun Dec 03, 2006 10:31 pm
by Splinter
Got the new turbo today, took some pictures next to a stock WRX turbo for comparison.
The turbo is a Deadbolt modified VF34, ported & polished exhaust side, including larger wastegate, coated exhaust side, ported inlet.
Flows 650CFM @ 14.7PSI in stock configuration, no idea what it'll do ported.
My new turbo on the left, stock on the right:
Stock on the left, new on the right:
Closeup of the exhaust port job:
Posted: Sun Dec 03, 2006 10:37 pm
by Imprezive
thats a sweet ass turbo! What are you doing to the fuel system? whats will your supporting mods be?
Posted: Sun Dec 03, 2006 10:44 pm
by Splinter
STi yellowtop injectors, walbro fuel pump
Supporting mods? An entire new powertrain and electrical system :P
Posted: Mon Dec 04, 2006 6:48 am
by Imprezive
Sounds exciting! :D
You should do parellel fuel rails to.
Posted: Wed Dec 06, 2006 2:08 am
by biggreen96
sweet man they look like they do good work!
now if they would only get around to doing good work on mine, I haven't driven my car since august :(.
Posted: Wed Dec 06, 2006 5:23 am
by Subtle
Just the post I need.
Splinter, as you know with the 5mt when you dont want too much boost you drive in a taller gear.
However, with any 4eat this cant be done. With a "built" and a high- stall torque converter the action can be spikey, which is not good when you might need modest response.
To tame this I've looked into the Forge adjustible waste gate actuator, with ,say, a 5 lb spring.. Problem is--their parts list as to the car not the turbo. Telling them a vf34 that might have been oem for a STi v. 7 doesn't seem to help.
What they need to know is how many bolts secure the bracket that holds the actuator to the compressor.
Well, mine still has the chimney and even with a good light I was unable to tell.
Can you check yours and let me know and while your at it could you also give me the length of the rod and the distance to were it makes the bend?
Thanks,
