cam swap with engine in car?
Posted: Tue Dec 05, 2006 5:39 am
by 206er
anyone done delta cams with the engine in the car? should be doable by the looks of it but wanted to hear from anyone who has done it. tips for success?
Posted: Thu Dec 07, 2006 7:00 am
by dzx
I'm pretty sure you have to remove the heads, at least one of them. One has the opening on the front where you can remove the cam but if I remember correctly, the other is pulled out on the firewall side.
Posted: Sun Dec 10, 2006 4:46 am
by 206er
shit.
maybe I could pull the engine off the mounts and rotate/move forward a little.
definitely not pulling the head off, would rather pull the motor.
Posted: Sun Dec 10, 2006 6:11 am
by scottzg
you can pull the heads with the engine in the car.
Posted: Sun Dec 10, 2006 7:01 am
by 206er
yeah, but I dont want to buy another head gasket as well when there's maybe 10k on them.
Posted: Sun Dec 10, 2006 7:38 pm
by scuzzy
206er wrote:yeah, but I dont want to buy another head gasket as well when there's maybe 10k on them.
which is easier, buying a headgasket or pulling the motor?
edit: #500 baby! :banana:
Posted: Tue Dec 12, 2006 6:14 pm
by 206er
Ive got other reasons to pull the motor so it will probably happen that way.
Posted: Tue Dec 12, 2006 6:42 pm
by Matt Monson
I'd pull the motor. It gets faster each time you do it...
