JoeP Pro-Z MBC Install
Posted: Fri Dec 15, 2006 6:15 pm
Well I got my JoeP MBC earlier this week, and installed it last night.
I fabbed up a bracket to mount it, and then mounted it to the stock wastegate solenoid bracket that I chopped up. I'm very happy with the install, it turned out really good.
I haven't had time to adjust the boost controller yet though....just install it.
Here's pics
http://www.main.experiencetherave.com:8 ... s/joepmbc/
For reference, here's pics of the stock setup
http://www.main.experiencetherave.com:8 ... P_6012.JPG
http://www.main.experiencetherave.com:8 ... P_6013.JPG
Posted: Sat Dec 16, 2006 4:58 am
by Imprezive
awesome! super subtle installation to!
Posted: Sun Dec 17, 2006 10:46 pm
Thanks!
I adjusted it on friday, it's easy to adjust, and works well. I had to turn it back down a little as I was hitting fuel cut when in the higher gears and on the freeway.
Posted: Mon Dec 18, 2006 4:44 pm
by magicmike
dont know why but none of your links ever work for me.
Posted: Mon Dec 18, 2006 4:53 pm
Probably because your ISP doesn't like the 8080 port. That port is typically specified as a proxy server port.
On any of the links I post, you can always modify the link to get it to work.
Remove the ":8080" at the end of the link, and change "http://www.main." to "https://www.main."
Like this:
https://www.main.experiencetherave.com/ ... s/joepmbc/
https://www.main.experiencetherave.com/ ... P_6012.JPG
https://www.main.experiencetherave.com/ ... P_6013.JPG
It will be slower due to it being a secure connection, but the links should work.
Posted: Mon Dec 18, 2006 5:11 pm
by magicmike
ahh you so smaht. I'll have to remember that though lol
nice work on the bracket by the way.
Posted: Mon Dec 18, 2006 7:15 pm
magicmike wrote:nice work on the bracket by the way.
Thanks :-D
Posted: Tue Dec 19, 2006 7:34 am
by bmxkelowna
i see only two places for vacuum lines on the mbc?
does it just bleed the extra to atmo instead of back into the intake like stock?
Posted: Tue Dec 19, 2006 8:05 pm
Yup, that's exactly what it does.
It be nice if it did bleed the air back into the intake, but I don't know of any MBC that does that.
Ultimately, I'd prefer an EBC, but until I get things figured out with EM, I figured it would hurt to play with a MBC.
