WTB: crank gear for a 94 BC
Posted: Thu Jan 04, 2007 11:17 pm
by waldo320
Does anyone have a crank gear the part that holds the timing belt to the crank? It has to be for a 94BC NA ? Let me know if you have one!
Posted: Thu Jan 04, 2007 11:31 pm
by n2x4
Do you have a bad gear? I had a gear with a bad keyway that I just ended up welding to the crank. Might save you having to get the part.
Posted: Fri Jan 05, 2007 12:15 am
by waldo320
No one of the tabs broke off when I was trying to get the nut off, then I used a 95-96 outback one and the tabs have a shorter duration thus not giving me good spark.
Posted: Fri Jan 05, 2007 12:44 am
by n2x4
Ah, that sucks. We've got a junkyard with like 12 subys here, so I'll see if they have anything tomorrow. I'd even be willing to meet you up in Canton if you'd like. I'll see what I can find and prices and let you know!
Posted: Fri Jan 05, 2007 5:18 am
by waldo320
That would be great get back to me on the prices, also I am narrowing it down a little bit between a ground, bad ignitor, or using the wrong crank gear I'm pretty sure it is one of those.
Posted: Fri Jan 05, 2007 10:59 pm
by n2x4
Called up the J/Y. He said $25 bucks for the gear if I pulled it. I guess it's in a flood car so the motor's bad and I can get stuff off it. Let me know if you're interested and what you wanna do!
Posted: Fri Jan 05, 2007 11:04 pm
by Splinter
n2x4 wrote:Do you have a bad gear? I had a gear with a bad keyway that I just ended up welding to the crank. Might save you having to get the part.
Gonna suck if your front main ever starts leaking.
Posted: Fri Jan 05, 2007 11:14 pm
by Matt Monson
$20 shipped. PM me for Pay Pal addy...
Posted: Sat Jan 06, 2007 12:42 am
by n2x4
Matt Monson wrote:$20 shipped. PM me for Pay Pal addy...
LoL, there's a better deal. Either way, we'll have to have a subaru meet sometime. I go to school at stark state, so I'm always in canton.
About welding the crank gear thing, yah you'd have to grind the weld off to get the gear back off if the seal went bad but just a tack isn't too bad to break. But you are right, a new gear is the right way to do it.
Posted: Sat Jan 06, 2007 1:27 am
by Matt Monson
The Ghetto Garage will ALWAYS beat junkyard prices...
