FS: 1992 Legacy GT Sport Sedan - Boston area
Posted: Fri Jan 05, 2007 1:23 am
by bman
I hate to see her go but, I no longer have the time or resources for her. I've only used her as a daily driver and I've got the paperwork on the services/parts since I've owned her. I'll post pics if there is interest.
$2500 or best offer.
Color:
RedWine Exterior
Gray Interior
249K miles
Turbo replaced at 60K
ACT clutch (06/02)
A/C compressor (05/04)
Radiator (7/04)
OEM cat-back exhaust (05/05)
all brake pads and rotors (10/06)
KYB AGX struts
Bilstein springs
JCSports cold air intake kit (uninstalled)
Hella Supertone horns
Complete aftermarket stereo system (Sony, Boston Acoutics, can provide more details)
(original radio/CD/casette also avail.)
car alarm
circa 96 alloy wheels w/ Michelin Artic Alpin
original alloy wheels (2 Dunlop Sport A2; 2 Yokohama Avid H4)
All fluids and timing belt changed every 60K.
Synthetic oil every change.
Known issues:
Dent on passenger-side, rear door. Does not affect lock, window or door handle.
Moderate rust. Mostly along fender wells.
Fiberglass patch driver-side front door (lower corner).
Heat shields rattle.
Thanks for looking,
Brian
Posted: Fri Jan 05, 2007 1:50 am
by smh0101
Pics?
Posted: Sat Jan 06, 2007 11:29 pm
by bman
Doesn't seem to be much interest here. I posted some pics on the LegacyGT site:
http://www.legacygt.com/forums/showthread.php?t=51455
Thanks,
Brian
SS FOR SALE
Posted: Sun Jan 07, 2007 7:30 am
by bepa
Is it still for sale? am interested. still 2500 is to high for me anyway. then the tow home. wish it was a little lighter.
good luck. will watch and see what happens by the 12th of january.
Posted: Tue Jan 09, 2007 1:36 am
by bman
bepa,
why tow it when you can drive it home? :D
what's happening on the 12th of january?
-Brian
Posted: Tue Jan 09, 2007 2:46 am
by Reason
Can you send pics to EJ25Legacy@aol.com
Posted: Wed Jan 10, 2007 10:47 am
by bepa
[quote="bman"]bepa,
-Brian[/quote]
12th is payday with 40 hours on the check. would have been able to get most of money. last night after pulling moving trailler 945 miles I found a rip in the tire. cords are showing. 285/45/18 is size and I need 2. 4 if your were talking doing it right. have to pass on this. good luck with the sale, Daniel
Posted: Wed Jan 10, 2007 6:38 pm
by Reason
Reason wrote:Can you send pics to EJ25Legacy@aol.com
Did you send them? Not sure if you did.
