Page 1 of 2
My NEW $167.50 Garret GT30(32)(35)....?
Posted: Fri Jan 05, 2007 1:42 am
by douglas vincent
I have no clue what it actually is because the only thing on the Turbo is Garret M24 ar.60
It was $202.50 shipped....
Brand new!
The inlet is 3" and out is 2", The inducer is 57 mm
[img]
http://www.vincentfurniture.com/photos/ ... d_1[1].jpg[/img]
And its got some wacky exhuaust housing, but its gonna work great for me! The word on the exhaust housing is "PRECISION"
The turbo wheel exducer is 55 mm.
[img]
http://www.vincentfurniture.com/photos/ ... 1_1[1].jpg[/img]
[img]
http://www.vincentfurniture.com/photos/ ... f_1[1].jpg[/img]
Posted: Fri Jan 05, 2007 1:48 am
by scuzzy
wow, that thing is huge, call me when you get it to spool.
Posted: Fri Jan 05, 2007 2:13 am
by douglas vincent
Pretty sure now that is a GT30R
Posted: Fri Jan 05, 2007 2:26 am
by skid542
Goodness Doug... You just don't do anything small do you
Are you going to use this to replace your supercharger setup?
Either way, I can't wait to see the installed pics.
Posted: Fri Jan 05, 2007 2:33 am
by gto7419
I feel like Doug has more forced induction setups than he does cars....
I sure wish I did....
(turbo envy)
Posted: Fri Jan 05, 2007 3:45 am
by Kelly
I'm pretty sure all GT series turbos are watercooled. That looks to me like a T4/T3 with a custom exhaust side. Pull off the downpipe section and take a pic of it. Is it 5 bolts, or 4?
Re: My NEW $167.50 Garret GT30(32)(35)....?
Posted: Fri Jan 05, 2007 5:02 pm
by pisces_0
douglas vincent wrote:It was $202.50 shipped....
Brand new!
How'd you end up scoring it for that cheap? Is there any axial or radial shaft play? I'd be concerned about either shaft play or leaking seals if it was that inexpensive. But, good deals do come along every once in a while...
The inducer is 57 mm...The turbo wheel exducer is 55 mm.
Where are you measuring these? The inducer is the smaller, outside edge of the compressor wheel and the exducer is the larger, inner edge of the compressor wheel. Fire off these two measurements and we can figure out what compressor wheel is in there (the 55mm & 57mm measurements don't match up to anything).
It's a Buick Grand National turbo put out by Precision Turbo & Engine
http://www.precisionturbo.net
Posted: Sat Jan 06, 2007 1:03 am
by Matt Monson
YOu must be excited since you said, " its got some wacky exhuaust housing, but its gonna work great for me" twice in a the same post. Do tell what you plan to do with it...
Posted: Sat Jan 06, 2007 1:31 am
by douglas vincent
The turbo will feed the SC. I want to get about 20-24 psi. Obviously the turbo could do that on its own, but spooling is going to be an issue. The SC starts at 8 psi at 2000 rpm, is at 11-12 by 3000. So with the Turbo thrown in it should hit the 20's fairly quick. And since the turbo is so huge, the air moving should be on the cooler side compared to a smaller turbo that is working harder to move the same amount of air.
Compressed air into another compressor is more than 1+1 = 2, The turbo should only have to move 8 psi into the SC to get 22 psi out total. Or so says the math.
But if it doesnt work, so what, at least I tried it!
Posted: Sat Jan 06, 2007 2:24 am
by i_c_the_light
Has anyone told you that you are insane, but in a good way insane?
Posted: Sat Jan 06, 2007 8:09 am
by Imprezive
hey doug, here is another ebay Ad, this is what his GT30R looks like:
http://cgi.ebay.com/ebaymotors/Garrett- ... enameZWDVW
Posted: Sat Jan 06, 2007 7:16 pm
by jnorion
How many engines do you think he'll go through perfecting this setup?
Posted: Sat Jan 06, 2007 9:08 pm
by scuzzy
jnorion wrote:How many engines do you think he'll go through perfecting this setup?
no less than seven?
Posted: Sun Jan 07, 2007 3:40 am
by douglas vincent
Hey now....
I may blow this one up, but it will only be because I will be making 300 plus whp!
Posted: Thu Jan 11, 2007 9:56 pm
by BAC5.2
Precision huh? They make a good turbo.
I'd be willing to bet they carry a V-band outlet flange for that exhaust housing. Bolty-Bolty!
Your going to feed the SC with the turbo?
Why not the other way around? Feed the turbo with the supercharged air. Isn't that how the HKS Twin-Charge kits for the old SC MR2's worked?
Posted: Thu Jan 11, 2007 10:01 pm
by Psychoreo
That would make sense to me, allow the pre-pressurized air from the supercharger pass the inducer fins. should help eliminate some of the lag no? But as we've all seen, Mr. Vincent is almost incapable of doing anything that would be considered "conventional" or "normal."
Good Luck, and I wish it the best. Keep Us posted!!!
Posted: Fri Jan 12, 2007 6:48 am
by AWD_addict
It doesn't really matter, it'll be worth it.
Posted: Fri Jan 12, 2007 7:34 am
by douglas vincent
It will work......
How well?
Thats another question....
However, one way or another, I am going to make some amazing power.
Posted: Fri Jan 12, 2007 1:33 pm
by BAC5.2
Doug, your my G-Fab Hero.
Now all you need is my Autometer Lunar gauges!
Posted: Tue Jan 16, 2007 9:20 am
by douglas vincent
I got my welder working tits today.... Turns out it had smaller diameter wire than required.... I wanted to chide my father, but since he's dead, its kinda hard
BUT!!!
I bought a metal chop saw and am set to go for building my uppipe and downpipe!
This turbo is going to rock!
Posted: Tue Jan 16, 2007 11:41 pm
by brando
gt32 FTW......... Only cool black cars have those turbos......
Well at least yours will move.. Mine is the prettiest driveway garnish ever!
Posted: Wed Jan 24, 2007 6:11 am
by douglas vincent
by douglas vincent
Posted: Wed Jan 24, 2007 6:19 am
by jnorion
I think you're missing a couple of pipes there...
Posted: Wed Jan 24, 2007 6:36 am
by bmxkelowna
and i thought changing my plugs are a bitch hah.
