Gauge vent pod holder and TT holder
Posted: Tue Jan 23, 2007 7:56 am
I made a gauge vent pod holder and turbo timer holder for my 91 Legacy. I had some extra black ABS plastic trim sheets sitting around so I thought I would experiment and see if I can make a gauge holder. So I got out my handy Dremel and made a rectangle for my turbo timer and got a 2" hole saw for my boost and air/fuel ratio gauge and drilled out 2 holes. I also made a blank vent panel to block the air.
I was just wondering how do you wire the turbo timer? I have a red (12v power +), black (ground -), yellow (accessory or illumination), blue (ignition ?), brown (hand brake). Now I dont know if I have this right but I thought yellow goes to the ignition. I dont know cause this is my first turbo timer. But any help would be helpful. Also I was wondering if the 91 SS has a 3 or 4 wire o2 sensor. Which wire do I tap into to get the signal for my AF ratio gauge? Thanks in advance!
Pic of wires for turbo timer:
Pic of vent gauge pod:
