'90 wagon door lock
Posted: Tue Feb 06, 2007 2:06 am
I have the "power" locks. I have done the "fix" on the remote. But, when I close the driver door it still locks and the key will not open it. The cylinder only turns a little. You can see the rocker trying to move and can also see the rocker is not fully depressed either. I have to open up the passenger side and pull the handle to get the driver door to open. I'm pretty sure I did Gary's fix properly, but it did not seem to fix my issue.
I've poked around the various subie sites and the only reference I have found is that maybe the linkage rod need to be "straigtened" to lengthen it a tad.
Is this a common problem? Any suggestions?
Thanx
Mike
Thanx
Mike
