Coolant reservoir
Posted: Sun Feb 11, 2007 8:29 pm
While nstalling my TMIC, I noticed the nipples for the coolant resavoir where broken. I removed the tank, drilled the hoels a bit bigger and JB Welded brass nippes in place of the plastic ones. These held up fine until I went on an impromptu rally race through a field and due to vibration, the TMIC knocked one of the nipples free. Unfortunately it is the turbo cooling line. Now I have a leak.
What I was wanting to do is fabricate a steel tank in place of the plastic one. I just was wondering if anyone has done this and cares to object. The only problem I see is heat soak and coolant inefficiancy because of the hot metal, but I could be over thinking the problem. Other than that it seems a good idea.
