Blitz Nur spec , yay.
Posted: Tue Mar 13, 2007 4:52 am
by HellBinder
for an 02 WRX, layed next to my OEM.
I need to use my old hangers. and maybe a short test pipe.
Posted: Wed Mar 14, 2007 2:49 am
by kawikid20o2
Its real short, how do you plan to adjust this?
Im running into issues extending my thermal research exhaust too.
I added 6in to make up for the shortend DP but the hangers in the back are close but the tip must be extended inorder to clear the bumper. There were other issues but im just interested in what issues you are having with yours.
~Justin
Posted: Wed Mar 14, 2007 4:07 am
by HellBinder
Ive got a full DP with cat delete on its way to make up for the space, should be here next week. but the only thing i worry about is the muffler section getting too close to where it runs under the rear k-member and rubbing the axle.
iam just gonna correct it all and fit it with new hangers but ive got about two more months before im ready to roll it out of the shop.
Posted: Wed Mar 14, 2007 4:40 am
by kawikid20o2
Well good luck, definitly post pics when its finished. I will too.
Posted: Thu Mar 29, 2007 6:50 am
by subinubi
I have the same exhaust. I am a bit concerned about the exhaust not exiting past the bumper. I'm also not crazy about the lower hanging muffler. After playing with it, I think I'll use a 16" cat between the non-flanged dp and midpipe. I will still need to put a small flanged chunck between the midpipe and rear section, about 6 ". Not sure if this is worth all the fabrication, though. I think it should flow dramatically different though.
