Cheap and Reliable Data Aquisition
Posted: Wed Mar 14, 2007 12:34 pm
Hey guys...Thought this might be useful for the do it yourselfers and the guys that want to get out of things cheap.
I have used these a lot at work and home to do a lot of things:
http://www.dataq.com/data-acquisition-s ... r-kits.htm
Just click on a few of them. There is some pretty cheap data aquisition options there. Several of them only have +/- 10 volt range...but if you know what your doing you can use them on pretty much anything.
The BAD:
-with the cheaper units there is a common grounding pin for all four channels which can cause some problems (depending on what your trying to do).
-the old models used RS232 (new ones might use USB)
-the the sample rate for the cheapo ones must be divided by the number of channels being used. In other words a sample rate of 200 Hz on one channel would mean 200 Hz whereas the same sample rate across 4 channels would only be 50 Hz. Still good enough to do a lot of cool little things.
-cheap models don't store the information...you would need to have the laptop hooked up to capture data.
The GOOD:
-There cheap and reliable!
-Easy to run (pretty much anyone could do it)
-Files can be saved in a number of formats (CSV can be converted to xls....etc.)
-Both digital and analog on all models (I think).
-It can be used as a low sample rate oscope.
The BAD:
The GOOD:
