It's a 3 wire connector. Based on how the valve works it's probably:
Push+
Pull+
Ground-
Anyone know which wire is which at the unit itself (not at the ECU)?
IAC wiring (at valve, not at ECU) - Legacy SS
Innovative Tuning
This is for the 90-91, but should be the same for the turbo
http://www.main.experiencetherave.com:8 ... C_diag.jpg
Innovative Tuning
welcome
