WTB: 91 SS aluminum MAF, Knock Sensor, coolant resavoir
Posted: Thu Mar 29, 2007 5:12 am
by boro
Like the title says. I need that stuff. My ECU is throwing those codes plus a few others that I am in the midst of handling. Basicallyit telling me that all my sensors are dead, or reading incorrectly. So before I try and source a new motor, I am going to try fixing these thigs and see if it helps.
So if any one has any spare parts:
-Aluminum MAF from a 91 SS
-91 knock sensor
-pressure sensor
-pressure switching solenoid (above the factory boost control)
-water temperature sensor (nm, i can get it for $20 at work)
Posted: Thu Mar 29, 2007 4:03 pm
by Matt Monson
I do have all of the parts that you need, but before you spend a bunch of money replacing things I would suggest troubleshooting the problem more accurately. Our cars are notorious for throwing multiple codes at single problems. In fact, based upon that list I am going to guess that the coolant sensor is the problem and the correct fix. Replace that first and get back to me...
Posted: Sat Mar 31, 2007 4:46 am
by boro
will do, thanks.
Posted: Mon Apr 09, 2007 9:43 am
by boro
ok so I am pulling off the manifold either tomorrow or tuesday to replace the coolant sensor and check out the knock sensor. I also need to replace the manifold gaskeet. I hope thi smakes a difference.
How much for the knock sensor if you still have it?
I also would like to grab that pressure switcher and MAP sensor set-up from the passanger side strut tower.
Shipped to 63043?
Thanks.
Posted: Tue Apr 10, 2007 3:24 am
by Jutboy
Won't the dealership replace your knocksensor for free...they did it on my 95 Impreza
Posted: Tue Apr 10, 2007 1:45 pm
by boro
Jutboy wrote:Won't the dealership replace your knocksensor for free...they did it on my 95 Impreza
Hmmmm...Whats all this then?
Posted: Fri Apr 13, 2007 2:49 am
by New92
Um yeah, do elaborate. Cause I went thru hell finding the new improved sensor and getting it installed.
Posted: Fri Apr 13, 2007 4:59 am
by ericem
THEY WILL?????? Are you kidding me? I just ordered one for $50 off on the internet, should have called my dealer, but did never mentioned anything.
Posted: Sat Apr 14, 2007 12:13 am
by boro
I went up there today, but I wa sin my work truck and didnt have my vin so they couldnt look it up. But I know I do have the old one, it wasnt recalled. Figured I may as well grab it from them. I wonder if they do all the work free, then I could have them, install new intake gaskets and my coolant sensor while they are at it!
Posted: Sat Apr 14, 2007 1:21 pm
by Radial GT1
You don't need to pull the intake to replace the coolant sensor. I just did mine and with the deep socket and some extensions I got to it just fine. One less thing to fuss with.
Posted: Sat Apr 14, 2007 4:42 pm
by boro
I need to replace my intake gaskets though. So yeah...
