help with engine codes, 24, 35, and 44
Posted: Sat Mar 31, 2007 3:27 pm
hello all,
i have a 91 leagcy sport sedan, turbo, auto trans, and i wonder if i could get a little help figuring out what to do about some trouble codes. while driving, i sometimes geta brief CEL, and don't notice any drivability problems, car seems fine, then the light goes off. also, occasionally it will just die, and i have to turn the key off and restart it.
i pulled the codes using the procedure from this site (very easy, great write up by the way) and got 24, 35, and 44. I think the car dieing is probably 24, the air control valve, but what do the others mean? i searched the site, and could only find that people don't always replace the canister purge solenoid valve, and that it is hard to do. how important is replaceing the part, and how hard is it? Also, what about 44, which appears to be something related to the turbo wastegate? what problems could it cause, and should i replace it?
thanks in advance.
thanks in advance.
