is anyone running one of these?
tmic with perrin bov??
'92 TW "Hana" ej20tt obd1 <too many to list< sold bought back
unfortunately i don't think that will work.
unless the angle of how it's connected to the flange can be changed, i'd say the throttle cable assembly will be in the way.
this is what mine looks like connected to an 03 wrx tmic
as you can see, mine is "just" clearing the throttle cables... and it sticks straight out from the flange. as it was i had to rotate the bov so the outlet was facing the drivers side fender, or it wouldn't have worked.
good luck
good luck
James L
'07 Magnum SXT - not stock
'93 Legacy Turbo SS - 5spd conv, vf34, intercooled, K&N, dual stage mbc 11/16psi, hks 3" turbo-back w/hi-flow cat, kyb's, ADR 18" rims w/225/35/18zr's, 7" touch screen w/race camera
ive got an HKS BOV but it doesnt recirculate... it doesnt look like yours does either...???? or does it?? our cars computer is asking for the recirculation = more power...
no mine does not. i'm in a 4eat anyway, so the whole argument of loss of power while shifting doesn't apply... it only vents when i take my foot off the accelerator, or when i brake.
As for what it does in a 5mt... in my opinion it's not a big deal... if you're going to be running crazy boost, on upgraded injectors and whatnot, you should probably be running some sort of EMS that can cope with the recirc, or buy one at that time.
i think it's either turbosmart or turboxs that has a recirc unit that fits our cars, if that's your goal.
base on the shape of the perrin, it looks designed to do the same or at least 50/50 atmos/recirc (the bottom looks modular). however again, it looks like it attaches in the place you want it the least.
PS, as far as i know the HKS has a recirc module. i swear i've seen it before, but looking at HKS site, i can't find it.
nevermind, here it is from their ssqv pdf.
James L
Bam!! i thought the recir hks was a complete diff unit.. thanks!! whats the 4eat mean neway? automatic?
glad i could help.
yeah, it means auto... oh well, can't have everything perfect right?
James L
recirculated the HKS!! works killer.. car runs better also.. the HKS swivels on the mount so their is no problem with clearence for the throtle cables. NICE
