just finished 5mt swap, car runs like shit
Posted: Thu Apr 19, 2007 12:52 am
by urabusturbo
i just finished getting a 5 speed into my 92 ss and now the car s not running very well. I never drove the car prior to the swap so im not positive on what could be wrong. it seems to hammer just fine until the car warms up and then it retards the timing and wont rev quickly, but i can slowly climb the revs to redline. it gives cole # 13(cam angle) 22(knock sensor) 31 (throttle sensor )44(duty solenoid) and 45(atmoshperic pressure sensor). I have tried using my old ecu for a 94 5mt ss but it gives the same codes. the car only has 112k and it has been parked for over a year but it ran well when i got it with a blown automatic.
Posted: Thu Apr 19, 2007 2:48 am
by 206er
it threw a code for the duty solenoid... did you clip the at/mt identifier pin?
do you have good grounds?
Posted: Thu Apr 19, 2007 2:59 am
by 555BCTurbo
I was getting the same symptoms and codes, and it ended up just being my knock sensor...
Posted: Thu Apr 19, 2007 5:45 pm
What all did you do for your wiring?
Posted: Thu Apr 19, 2007 9:22 pm
by legacy92ej22t
555BCTurbo wrote:I was getting the same symptoms and codes, and it ended up just being my knock sensor...
+1
I too has similar symptoms and codes once and it was the knock sensor.
Posted: Fri Apr 20, 2007 1:53 am
by urabusturbo
how hard is it to change a knock sensor and how much should i spend on one?
Posted: Fri Apr 20, 2007 6:45 am
by BSOD2600
A long extension on your socket should be able to reach it. Just don't over tighten the bolt and crack the plastic.
