Page 1 of 3
				What transmissions are you 16g+ guys running?
				Posted: Thu Apr 19, 2007 9:31 pm
				by shemoves
				Trying to get an idea of what power/tranny/driving style combos are working for people...
				Posted: Thu Apr 19, 2007 11:25 pm
				by Innovative Tuning
				WRX tranny, RS Tranny, and Legacy SS tranny are not working for me. FP Green at 25-26 psi...just rolling the throttle on in gear is blowing them apart.
I used up most of my extra trannies and now I can't get into boost until my RA geared WRX tranny is ready to go in.
				Posted: Fri Apr 20, 2007 12:53 am
				by shemoves
				Dang man...what are you puttin' down? 400?
I'm not gonna have near that btw...I'll prolly set it @ 10 psi to be really safe (12-14 on very rare occasion).
You said you used up most of your extra trannies...have any left you are looking to sell?
				Posted: Fri Apr 20, 2007 1:46 am
				by jake15
				I'm running a jdm 4.11 tranny now, its held up for about a year and some change, i ran a t-leg case and 97 impreza gears before that and it held up for about 6 months then 2nd gear blew, and before that it was an automatic which i stripped the pinion shaft teeth off of.
				Posted: Fri Apr 20, 2007 2:34 am
				by douglas vincent
				Doing lots of 12.7-13.0 @ 110 mph with a stock 1990 NA tranny.  haha
				Posted: Fri Apr 20, 2007 3:24 am
				by Soul Shinobi
				Driving carefully on the stock 255,000 mile old tranny.
What the hell is 16g+?
				Posted: Fri Apr 20, 2007 3:31 am
				by Subaru for Life
				I think, they're talking about the larger TD05 16g turbo???
Not a turbo guy either, don't know none of that stuff
Subaru_for_Life
Soul Shinobi wrote:Driving carefully on the stock 255,000 mile old tranny.
				Posted: Fri Apr 20, 2007 4:03 am
				by shemoves
				jake15 wrote:I'm running a jdm 4.11 tranny now, its held up for about a year and some change, i ran a t-leg case and 97 impreza gears before that and it held up for about 6 months then 2nd gear blew, and before that it was an automatic which i stripped the pinion shaft teeth off of.
I had one of those two, but I sold it before putting it in.  This is supposed to be my DD, so I'd like longer gearing.
				Posted: Fri Apr 20, 2007 4:19 am
				by 93Leg-c
				Subaru for Life wrote:I think, they're talking about the larger TD05 16g turbo???
Soul Shinobi wrote:What the hell is 16g+?
That's correct!
				Posted: Fri Apr 20, 2007 1:22 pm
				shemoves wrote:Dang man...what are you puttin' down? 400?
No idea... I just street tuned it. I have another legacy turbo tranny, but I'm saving that just in case.
I didn't hurt anything at 22 psi on a VF39. The trannies aren't super weak, but they do have a limit. At 12-15 psi a 16g is just starting to come to life and I wouldn't expect to blow any trannies with that kind of power...unless you break it launching it.
				Posted: Fri Apr 20, 2007 1:33 pm
				by legacy92ej22t
				Shemoves-The tranny (OEM SS) that's currently in your car came from Innovative Tuning.
I had it in about 5-6 months before it sheared 1st.
Tranny before that was the OEM SS tranny and it lasted about 6 months w/ the 16G also...
I'd stick in either a MY03+ WRX tranny (beefier 2nd gear) or a JDM STI 5mt.
				Posted: Fri Apr 20, 2007 4:03 pm
				by shemoves
				Matt, did you do a lot of launches or hard shifts on it? Or was it just 'normal' wear and tear from the increased power?  I'm wondering if I could just be nice while shifting and make a stock replacement last a while...
Hey, congrats on the new Legacy
				Posted: Fri Apr 20, 2007 6:45 pm
				by n2x4
If you do decide the WRX route, folklore on NASIOC says that 05 is the best of all since it's got the beefier gears and better syncros.
06+ is worse since it's got the 3.70 gearing which puts more stress on the drivetrain.
That's what they say anyway.
				Posted: Fri Apr 20, 2007 8:41 pm
				by legacy92ej22t
				shemoves wrote:Matt, did you do a lot of launches or hard shifts on it? Or was it just 'normal' wear and tear from the increased power?  I'm wondering if I could just be nice while shifting and make a stock replacement last a while...
No launches or hard shifting. Just normal wear and tear on the one currently in the car. It let go while turning a corner in the city doing maybe 10 mph, off boost.
My OEM tranny got launched a few times when I raced the car but nothing too squirlee. It blew 2nd when I rolled on boost, had my kid in the car and everything. I wasn't driving it hard at all.
				Posted: Fri Apr 20, 2007 9:07 pm
				by 92whitelegacy
				4.11 tranny and rear diff Deadbolt TDO5-16G  FOR THE MOTHER FUCKIN WIN!......your right about the gears being short, my car tops out at 135..not cause of loss of power..but because of the 5th gear rev limit lol.
				Posted: Wed May 02, 2007 6:59 pm
				by shemoves
				legacy92ej22t wrote:shemoves wrote:Matt, did you do a lot of launches or hard shifts on it? Or was it just 'normal' wear and tear from the increased power?  I'm wondering if I could just be nice while shifting and make a stock replacement last a while...
If I were to drop the 16g down to 9 psi (IIRC, that is what you said the lowest the BC would allow), how long do you think a stock replacement tranny would last driving normally (good shifts, but not afraid to down shift to pass on the freeway or give it some 'go' from a slow roll)?
				Posted: Wed May 02, 2007 7:08 pm
				impossible to say really...
It should last a long time since a 16g at 9 psi will barely make more power than the stock turbo. Maybe 20hp with all other things equal. The 16g won't really come to life until you run more boost.
				Posted: Wed May 02, 2007 8:20 pm
				by douglas vincent
				Once again I will chime in on the reliability of the NA tranny I am using.  350-400 torque, about 36 drag launches on this power so far, running an unsprung six puck.  And plenty of on-ramp tuning sessions.....
				Posted: Wed May 02, 2007 9:38 pm
				That's crazy man. All I had to do was roll on the throttle and my mint Impreza RS trans was gone.
				Posted: Wed May 02, 2007 10:56 pm
				by BAC5.2
				legacy92ej22t wrote:No launches or hard shifting. Just normal wear and tear on the one currently in the car. It let go while turning a corner in the city doing maybe 10 mph, off boost.
That's how the stock tranny in mine went.  Pulling into the MVA to get the tags for my Forester, pop goes 2nd.
I ran the OEM tranny, followed by a PPG straight cut synchro box (RWD), and then a dogbox.
The owner after me ran a stock WRX tranny (RWD), followed by a different dogbox, and then back to a stock WRX tranny (AWD).
The dogbox was, by far, my favorite.
As for which WRX tranny is the strongest?  They all suck, truthfully.  RA gears aren't really much stronger than stock WRX gears (I can explain, if necessary).  Not strong enough to warrant the install money and time.
The only "strong" stock Subaru tranny is the 6-speed, and even they pop.
				Posted: Sun May 06, 2007 6:00 pm
				by douglas vincent
				Got two 12.5 1/4 miles on my stock NA tranny last night, running about 112 mph!
				Posted: Mon May 07, 2007 5:53 am
				by 93forestpearl
				GT3071R with an '05 6MT.   I don't think I'll be throwing down enough power to push its limits, plus my axels should be the give point anyways.
				Posted: Tue May 08, 2007 3:44 pm
				by scuzzy
				other than the synchros wearing out in my NA 4.11 91 tranny, it's doing great  on the track and on the street, granted I'm not boosting yet, but abuse is abuse.
it makes you wonder what the deal is with the NA trannys, and why they survive longer than other's.
				Posted: Wed May 09, 2007 1:28 am
				by AWD_addict
				Maybe the difference in clutch type gives different shock loads?
				Posted: Wed May 09, 2007 4:00 am
				by georryan
				I've been running a stock  5spd tranny for a about a year with a vf8 running 15psi of boost without issue.
I really think it is just the draw.  Before this  was running a stock tranny with 210k miles on it.  No problems other than synchros were going out.  The current tranny has maybe 70k miles on it.
I don't drop the clutch though.  Most of my starts are rolling starts from the lights and I'll munch it once I'm rolling.  I have a stage 1 excedy clutch currently for a wrx, so nothing exception, but better than stock.
