Missing tube off Duty Solenoid Valve?
Posted: Fri Apr 27, 2007 2:38 am
by BSOD2600
I was changing my fuel filter this afternoon and noticed that I had a loose tube. I traced it back to what I think is the Duty Solenoid Valve (16102AA012). It comes off the bottom of it. Looking around, I couldn't see anything obvious where it attaches.
Anyone have some pointers?
Posted: Fri Apr 27, 2007 3:18 am
by DLC
I think it might be a relief hose, and should probalby connect to the bit that goes between the airbox and the turbo inlet.
Posted: Fri Apr 27, 2007 4:01 am
by IronMonkeyL255
DLC wrote:I think it might be a relief hose, and should probalby connect to the bit that goes between the airbox and the turbo inlet.
I agree with him.
My car didn't seem to want to boost quite right when I had it capped off.
Posted: Fri Apr 27, 2007 6:09 am
by BSOD2600
There are no visible holes on the airbox. Is it underneath, requiring the airbox and the thing holding the MAF, to be removed?
Posted: Mon Apr 30, 2007 5:25 pm
There's a nipple on the resonator box after the MAF sensor, before the turbo. That's where it gets connected to.
Posted: Mon Apr 30, 2007 5:31 pm
by IronMonkeyL255
Legacy777 wrote:There's a nipple on the resonator box after the MAF sensor, before the turbo. That's where it gets connected to.
Though it may have broken off.
I know I broke mine off one day while putting the intake back together. Ended up doing the coffee mug mod instead of replacing it.
