transmission for a 93ss
chochocho
Post by chochocho »
hello there,
i wanted to find out if a 90 or 91 legacy (n/a or ss) can be installed into a 93 legacy SS.
are there lots of difference between years? and if there are any difference between n/a versus ss transmission?
thanks in advance.
Is your 93 AT or MT? Are you sticking with the same trans type, ie replacement trans, or are you swapping, (AT to MT)
The n/a 90 & 91 cars have a 4.111 final drive ratio. The 91 SS has the same final drive ratio as the 93, and will for the most part be a direct swap.
