What is a pressure exchange solenoid?
Posted: Fri May 04, 2007 11:49 pm
by Jutboy
I searched around and couldn't mind a definition of what this item is and what does that knob that turns do?
Thanks - I appreciate it - Justin
Posted: Sat May 05, 2007 12:23 am
by rallysam
Basically, there's a pressure sensor nearby which is connected to that solenoid valve by a tube. The ECU tells the solenoid valve to connect either atmospheric pressure OR intake manifold pressure to the pressure sensor, depending on which the ECU wants to measure at the moment.
The dial is not a dial, it's just a plastic hood where the solenoid valve gets atmospheric air pressure from. There's nothing to adjust.
Posted: Sat May 05, 2007 1:42 pm
by Jutboy
Thanks for the explination
Posted: Sun May 06, 2007 9:55 pm
by boro
I need one PDQ. Any body have a spare?
