Refilling the coolant system, burping the lines, how-to???
Posted: Sun May 06, 2007 3:02 am
I just spent the better half of the last 2 days pulling my intake manifold to replace some stupid coolant bypass line that leads from the coolant passage to the manifold.
My radiator and everything is empty, and I need to refill it. I want to know if there is a special procedure in order to refill the coolant as to reduce the chances of air bubbles. And how to burp the lines if I do have any?
I blew 2 coolant lines in 3 days, and i heard if I dont refill the coolant propperly, it could cause problems and lead to blown lines. I'll be damned if im going to do this job again.
Thanks for any help in advance.
-Brian
P.S. This is for my 1993 Legacy Turbo Wagon.
-Brian
