odd reving issue
Posted: Fri May 18, 2007 7:39 pm
by ramathorn
okay now that my car is all back together (minus seats) i started it up and reved it a little bit to make sure everything is good. well i took it upto 4500 and then it just fell flat on its face like it was hitting a rev limiter or something. no cel, no codes, nothing so im kinda stumped on what the issue could be. could someone maybe toss some ideas out there for me to possibly trouble shoot?
Posted: Mon May 21, 2007 5:25 pm
I know you may have this info in another thread, but can you please elaborate on the work you all did, or post a link to that thread.
Posted: Tue May 22, 2007 2:04 am
by ramathorn
oh wow lets recap what i have HAD to do get the car back up and running again in the past 2 weeks or so.
rewire the engine
added intake
replace and rewire new tps
get of open emissions lines
cap old vacume line
clean maf
replace battery
redo strut and springs
fix exhaust leaks
fix saab tmic install (derig it and get it setup properly)
replace some fuses
all amongst some other things as well
anyhow i figured out my problem.
Posted: Tue May 22, 2007 5:41 pm
care to share what the problem was and what you did to fix it.
Posted: Wed May 23, 2007 1:58 am
by ramathorn
well it could have been a number of things that i went through and fixed.
cleaning the maf
adjusting the throttle linkage
cleaning the tb
replacing some of the vaccume lines
fixing the saab tmic setup
so i guess by checking those things if someone elese that has the same problem they might be able to narrow it down.
