sensor harness
Posted: Fri May 25, 2007 3:03 am
by gto7419
I have one harness left over after doing my swap. The one plug comes off of the harness that leaves the firewall and attaches to the knock sensor, cam sensor, and crank sensor.
Can anyone remember off the top of their head what the other one is for?
Posted: Fri May 25, 2007 6:10 am
by PhyrraM
4-pin connector with only 3 pins/wires used?
O2 sensor, If I recall corrrectly.
Posted: Fri May 25, 2007 2:29 pm
by gto7419
Wow, I cant believe I forgot that one.... Now all I have to do is exhaust, battery, and i/c and I should be able to crank it :-D
Thank you!!!
