Inhibitor switch
Posted: Mon May 28, 2007 9:42 am
by Tleg93
I've been throwing a code 51 (inhibitor switch) on my legacy. What is the inhibitor swtich, where is it and how can I get to it? Any info would be appreciated.
Posted: Tue May 29, 2007 5:42 pm
It's mounted on the side of the transmission, and basically is the electronic switch on the transmission that tells the TCU/ECU what gear the Trans is in.
Posted: Tue May 29, 2007 6:16 pm
by gto7419
Hmmm, there are two of these sensor things on my tranny. One for each shaft?
Posted: Wed May 30, 2007 5:31 pm
You see where the shifter cable goes
http://www.surrealmirage.com/subaru/ima ... P_3217.JPG
Where it attaches to the trans is the inhibitor switch. That whole assembly is the switch.
Posted: Thu May 31, 2007 4:18 am
by Tleg93
Thanks Josh, that clears that up.
