How-To Install a New Alternator: Just to Show How Easy It Is
Posted: Thu Jun 07, 2007 11:27 pm
Installing a new Alternator
on a 91 legacy turbo
I was having hesitation issues ever since I bought the car back in September. At first I thought it was just how the car was, being that it was the first legacy I had driven, as well as being stock, 16 years old and not 100% maintained. However, after intercooling and raising boost something began to irk me. The hesitation problem seemed to be intermittent and I began to do some research here on the boards, everything fit for the alternator being my problem as I had new plugs and wires. I Ordered a new Alternator and it sat for a few weeks because I was hesitant about changing it out. It looked like it would be really easy but I had never messed with belts before. One thing I've learned with car work is that it is never as easy in my head as it is once I'm working on the car.
To sum it up, it was easier than I had thought. That's why I am writing this up for any new guys that may have any hesitation about this.
Need:
10 & 12 mm sockets or wrenches
New Alternator
30-45 minutes
Steps:
Unbolt the cover over the A/C Compressor. 2 10mm bolts
Loosen the Drivers side Alt stud (12 mm), mind the nut plate in the back of the Alt, don't take it all the way out yet this is just so you can do the next step.
Remove the other protective plate, 1 10 mm bolt, tilt to the drivers side, plate should come free.
Loosen the belt tension bolt 12 mm, this lets tension off the belt so that you can take out the old alternator.
Remove the 12 mm bolt connecting the passenger side of the Alt and then the 12 mm stud on the drivers side, pay attention to all the washers.
Old out, new in. put it all back like you found it.
I tightened the belt about as tight as it had been and gave it a 1/4 turn, it seems fine. If anyone could give exact info that would be great.
I never thought of an alternator as a performance mod until I took the car into work this AM... what a difference! Everything is smoother, tighter and faster. If you have hesitation issues, do your car a favor and swap it out with a better unit.
Please let me know if I'm an idiot and missed something or am very mistaken.
Need:
New Alternator
30-45 minutes
Steps:
