Foglights questions
Posted: Fri Jun 15, 2007 7:31 pm
by SnowQueen
Couple of Legacy fog light questions...
- How do I remove the foglight cluster in orer to change the bulb?
- What does the light (red circled) on the right do? It doesn't come on with either sidelights / headlights / main beam or fogs?
Mike
Posted: Fri Jun 15, 2007 7:40 pm
by evolutionmovement
Does it come on with the blinker? Can you access the back of the light unit through the wheel well?
Posted: Fri Jun 15, 2007 7:44 pm
by SnowQueen
No...it doesn't come on with the indicator either. I suspect that it's a second sidelight which has been either screwed around with, else both L & R bulbs are dead.
I'm painting up the calipers tomorrow and will have a look after peeling back the wheel arch plastic.
