1999 Impreza Outback front struts/springs swap into 92 LS ?
Posted: Sun Jun 24, 2007 4:15 pm
I pulled a like new set of Monroe Sensa Trac struts/springs/top plates off a 1999 Impreza Outback Sport. Does anyone know if the Imprezza Outback Sport front coil springs are longer and/or stiffer than my 1992 Legacy LS stock coil springs and if the lower spring perch on the Impreza Outback Sport front strut is higher. I really want to use these if I can. The top plates (bearing plates) are the same, but I do not want to raise my front end, nor do I want to cause any unwanted positive camber
