wtb: Im going to be doing a 5speed swap (need parts)
Posted: Tue Jun 26, 2007 5:44 am
Hi
ok so just picked up another 91 ss but she's an auto not to worrie im going to be doing a 5speed swap. So....whos got parts for me Im not 100% shure what ill be needing but i figure you guys know. The basics of what ill proably need are as follows
Transmission---still need 1
Clutch----going to buy a new 1
Flywheel---already have one from an sti unshure if it will work
Pressure plate--comes in clutch kit
Pilot Bearing---also in clutch kit
Throw-out Bearing---in clutch kit
Driveshaft----I will be needing 1
Shifter assembly----need 1
Pedal assembly, (brake & clutch)---still need 1
Clutch master and slave cylinder---need this
Hydraulic clutch line---still need this
Starter Motor----dont know if the auto one will work or no
3-piece rear crossmember----dont have 1 will need it
Recommended: engine and transmission mounts--proably going to go with group N mounts
Let me know what u guys have and how much thanks.
