How do I adjust my hydraulic clutch?
Posted: Wed Jun 27, 2007 6:20 am
As stated, how do I adjust my hydraulic clutch?
I swapped my '91 SS to a 5-speed, and the clutch releases very near the top of the pedal stroke. My hydraulic system isn't leaking any, and the pedal is stiff as all hell. When I say stiff, I mean stiffer than a stage 3 Roush Mustang (strong clutch actuated by a cable).......
I think this is because the clutch is releasing at the same portion of the stroke where the 'compensator' spring is pushing instead of pulling the pedal.
Which way should I adjust it?
