Do GR2 struts for 90 legacy wagon fit 93?
Posted: Fri Jun 29, 2007 3:16 pm
by ericem
Hey, i did a search, but just to verify i only understood that the top hat is different in the rear?? Anything else major? Do i just change the top hats. KYB GR2's have different part numbers for a 90 and 93.
Posted: Fri Jun 29, 2007 4:49 pm
by NuclearBacon
i heard its because of the ride height. not of the spring and shock, but the actual placement of the tophat mounting thats been welded to the unibody. theres about a 1 1/2 inch difference giving a 92 - 94 car a 1 1/2" raise.
Posted: Fri Jun 29, 2007 5:26 pm
by ericem
hmm. The front's are still the same im guessing correct? Might be fine in the rear. But might look stupid. Then again my rear springs are worn so it probably lost that inch already.
Posted: Mon Jul 30, 2007 6:52 am
by ardie720
Old Post I know but I figure if you can buy them for the car they should fit right.
http://www.ajusa.com/cgi-bin/stores/pro ... ory_lookup
Just thought that might help
I'm wanting some for my 90 and found them here.
Posted: Mon Jul 30, 2007 7:43 am
by jamal
me wrote:the lower spring perches are attached to the strut in different locations. The chassis is the same, it's just the springs are different lengths and shapes.
http://bbs.legacycentral.org/viewtopic.php?t=17352
that combined with 90-91 = tapered rear springs
and 92-94 = not tapered
92-94 springs are shorter in the front and taller in the rear, so using older 90-91 struts will really mess up the ride height.
I posted that a few weeks ago and the thread is still on the first page. Look around a bit before posting.
