Need a quick answer. Searched but need to double check.
Posted: Fri Jul 13, 2007 12:22 am
I am going to the junkyard Saturday to pull a bunch of parts for my 90 Legacy L. I want to do the AWD conversion as well. I found two AWD Subies. One 97-98 Outback and one 93-94 Legacy. Does it matter which rear end I get? I want to put the Outback springs and struts on for the extra height so can I just bolt up the entire Outback rear end? What about the Outback tranny, I believe it was a 5spd. It's a non-turbo car by the way. From what I've read it looks like the Outback parts will work, I just want to double check before I spend all day removing this stuff. Also, does anyone know of any "special" problems I might run into doing this? I believe that's it, wish me luck and any help is greatly appreciated.
Thanks,
Brandon
Thanks,
Brandon
