sluggish fuel gauge
Posted: Wed Aug 01, 2007 10:55 pm
by jefferson
After filling up with fuel my gauge has started going up very slowly and then never really reaches the full mark. Has anyone run into this before? Are the connections for that under the rear seat? I also ran it really low on fuel this last time and the low fuel light never came on. It's not really a big problem, but it bugs me and I would like to have it work right. Thanks.
Jeff
Posted: Wed Aug 01, 2007 11:03 pm
by ericem
Mine has always been slow. But always went up to full. There is a fuel sender cleaner called techron or tectron?? Try it, might just be water in the tank.
Posted: Thu Aug 02, 2007 6:02 pm
The main connector is under the seat, however the access panels for the pump & sender are in the trunk.
I messed around with the damn senders, and ended up replacing them both, as they were causing the gauge to drop, and all around be a pain.
here's info on how to test the low fuel light
http://www.main.experiencetherave.com:8 ... t_test.jpg
Posted: Sun Aug 05, 2007 3:27 am
by Soul Shinobi
Where's connector R22?
Posted: Thu Aug 09, 2007 6:24 pm
under the rear seat on the passenger side....the main fuel pump connector.
Posted: Thu Aug 09, 2007 11:53 pm
by jefferson
Thanks for the info guys. I may pull the back seat and check that light tonight. On second thought I may wait until it cools down outside which could be a long ways off.
I am also thinking about replacing the fuel tank as the bottom of mine has been crushed pretty good. I may not gain a whole lot of capacity, but I tend to push things when it comes to getting all I can out of a tank it would be nice to have every little bit.
Jeff
