looking for aluminum chargepipe for v2 slanty i/c
Posted: Tue Aug 07, 2007 10:22 pm
by rockethound
Anyone have one of the MRT aluminum chargepipes for the v2 slanty i/c that they'd like to sell? I want to install a TD05-16G in my '92 ss and I'd rather not hack up a good factory pipe if I can avoid it.
Jeff
Posted: Tue Aug 07, 2007 11:18 pm
by greg donovan
these are pretty tricky to find from what i have seen. right up there with the AVO charge pipe.
the used one i bought (but havent installed yet) came with a straight piece of tubing welded to a 90* on a plate to fit the inlet for the IC. the pipe also had a fitting wleded on it for the recirc valve. all i need to do is figure out how to connect the pipe to the turbo.
good luck.
Posted: Fri Aug 10, 2007 3:43 am
by EvilAsPie
I might have a "slanty" intercooler for sale soon. I recently bought a 93 legacy SS with one installed on it. I really don't like the way it fits in this car nor the way it lines up with the hood scoop.
I am working in sourcing a WRX TMIC locally. I have seen these mounted in these cars before and they seam to line up pretty well when done right.
I will let you know.
