Sti v...
Posted: Fri Aug 10, 2007 3:49 am
by Darkseb
Anyone have some info on which jdm sti v(only motor) are the best on the aspect of perfomance,durability,compatibility and cost? Any chart of all the special edition sti?
Posted: Fri Aug 10, 2007 4:14 am
by Darkseb
nasioc maybe....???
Posted: Fri Aug 10, 2007 5:05 am
by PhyrraM
V1 and V2 are the only easy swaps as far as wiring is concerned. Only 2 wires are required to be added to the vehicles harness, with a few more optional. If you convert the engine to wasted spark you can even get it running on a stock EJ22t ECU and let piggybacks handle the tuning.
All 5speed swaps are basically the same mechanically. 6speeds a bit more involved.
I can't help too much as far as engine strength is concerned. Most factory turbo Subarus are pretty stout with proper maintenance however. I would guess 300 crank HP is safe with any well maintaned motor. 400+ on some of the later or special versions.
Yes, Nasioc is a good place to start. Just always keep in mind....sometimes the interweb lies.
Posted: Sat Aug 11, 2007 12:27 am
by Darkseb
thanks thats a cool info.Today i found some interesting fact on nasioc they say that v7 are probably the best(on impreza chassis) but the best bang for the buck still an ej22t!!!
