WTB: plastic oil line
Posted: Sat Aug 11, 2007 8:11 pm
by adema2626
The one im taking about is the one that runs under the intake and it runs along side the fuel lines and it has a nipple in about the center of the motor where it connects to the motor. Anyone have one of theses that is not broken and they wanna sell me?
Posted: Sun Aug 12, 2007 3:52 pm
by Threshld1
I do believe you are talking about the front crank vent line. Its a plastic line running from a vent on the front of the block by the oil pressure sender to both heads correct? The one that shatters into 500 pieces if you touch it. Its got nothing to do with oil, its just an extra vent for the crank to prevent pressure buildup at high rpms. I just replaced it with 1/2" heater hose and a T-fitting.
Posted: Sun Aug 12, 2007 7:45 pm
by adema2626
Hey thanks all do just that, It will last longer now to :)
