FHI 4-pots
Posted: Thu Aug 16, 2007 2:13 am
by Splinter
I dont know if there were any questions about this or not, but just in case:
FHI 4-pots are a direct bolt on.
Posted: Thu Aug 16, 2007 3:42 am
by stipro
Like direct, direct?? Just bolt on go, I mean stop?
Posted: Thu Aug 16, 2007 3:52 am
by Splinter
You'll need bigger wheels, but apart from that ya
Posted: Thu Aug 16, 2007 4:18 am
by stipro
I have 17" GTB/RSB wheels they'll fit :)
Posted: Thu Aug 16, 2007 4:33 am
by Splinter
Im also not sure about the brake hoses, come to think of it
Buuut
You should really get some SS lines anyway ;)
Posted: Thu Aug 16, 2007 5:10 am
by 86ruguy
I am curious as to what "FHI" means. Also, what is the smallest wheel diameter that they will fit under. Thanx.
Posted: Thu Aug 16, 2007 5:13 am
by mike270
FHI = Fuji Heavy Industries = parent company of Subaru.
http://www.subaru.com/common/about/about_fhi.jsp
Posted: Thu Aug 16, 2007 5:14 am
by 555BCTurbo
86ruguy wrote:I am curious as to what "FHI" means. Also, what is the smallest wheel diameter that they will fit under. Thanx.
Fuji Heavy Industries...and you generally must have at least a 17" wheel unless you have either 2.5 RS 5 or 6 spoke 16" wheels
Posted: Thu Aug 16, 2007 5:27 am
by Splinter
I specify FHI - Fuji Heavy Industry, as opposed to the Brembo 4-pots, which I have no idea if they bolt on or not. I'd expect no.
Posted: Thu Aug 16, 2007 7:35 am
by know1
a true service to the community ;)
hmm wonder if they would fit over 16" forester rims...
Posted: Thu Aug 16, 2007 10:55 am
by jamal
I have heard that some non- "16x7 98-01 2.5RS 16"" Subaru wheels will fit over these.
And actually more 15" wheels fit over the 4-pots than do WRX 2-pots. 2-pots stick out farther radially and 4-pots are wider but shorter.
