My Homemade Black interior
Posted: Sun Aug 19, 2007 9:53 pm
by livestrong14
Last summer:
Now!!!!
Black carpet
Satin black dash, door panels, pillars, etc.
Black and red stitched suede shift boot
JDM Legacy GT Spec B steering wheel
Kartboy shift knob
01' 2.5RS front and rear seats
Custom graphite door cards
Autometer Ultra Lite Boost and Oil Pressure gauges
Red needle gauges
Enjoy!
Posted: Mon Aug 20, 2007 12:39 am
by baddriver
That looks great!!
How's the seat height with the front RS seats, and how are the gaps with the rears.
I have a torn front seat, and I need to replace them sometime.
Also how much work went into the door cards?
Posted: Mon Aug 20, 2007 12:57 am
by livestrong14
Thanks man! The door cards were the hardest part. The doors had to be totally dis-assembled, stripped of their cards, and prepped. Then you have to go back through with spray adhesive and attach the new fabric to the existing material on the card itself.
The height was the same as the stock seats pulled all the way up in my opinion. They are sooooo much more supportive! The rears fit perfectly everywhere, but not quite 100% perfect at the bottom becasue mine are out of a coupe.
Otherwise, can't complain!
Posted: Mon Aug 20, 2007 2:06 am
by Splinter
looks awesome!
Posted: Mon Aug 20, 2007 2:15 am
by livestrong14
Thanks Splinter!
Posted: Mon Aug 20, 2007 9:51 am
by AWD_addict
Cool!
What kind of paint did you use?
Did you remove the dash?
Posted: Mon Aug 20, 2007 5:13 pm
by livestrong14
Yep, the whole interior had to be removed. I used VHT's vinyl dye for the dash and door panels, and another company called Plasticoat for the trim. Very good quality stuff!
Posted: Mon Sep 10, 2007 5:40 pm
by Adam_Ant
Where did you get the dye none of the local auto shops have dye all they have is paint.
Posted: Mon Sep 10, 2007 10:42 pm
by livestrong14
Anybody carry VHT products near you? You could probably order it online from VHT. It is called satin black vinyl dye.
Posted: Mon Sep 10, 2007 11:06 pm
by evolutionmovement
An auto body supplier should have it.
Posted: Sat Sep 15, 2007 4:08 am
by SuperRallyRoo
looks good... Do you have to have a airbag in that steering wheel in order to get the cover to stay on?
Posted: Mon Sep 17, 2007 11:58 pm
by livestrong14
^^ Nope, just has two #10's that hold the cover on. We were still able to keep the horns and cruise control with this setup too.
Posted: Tue Sep 18, 2007 1:35 am
by SuperRallyRoo
sweet cause I just took out an airbag unit and those fuckers weight alot!
Posted: Tue Sep 25, 2007 7:54 am
by tsbpenguin
How many cans of the dye did you have to buy? did you get the prep stuff too or just the dye?
Posted: Wed Sep 26, 2007 12:24 am
by livestrong14
I had to get some vinyl prep. I forget the name of the brand. It was around $14 per can. I think the whole carpet, dash, and door panels took 6 cans of dye.
