14s on turbo legacy? big no no?
dirtyhandssubaru555
i was just told that i shouldn't have 14 inch rims on my turbo leg, do to the fact that they don't clear the calipers, i am getting some rubing sounds but only under hard cornering. the car came with 14s when i bought it and i haven't drove it much. so should i change to stock 15s?
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
Saskatoon Subaru
Yes. They rub when you turn due to flexing of the wheel. Regardless, the car will handle better with some larger alloys (within reason of course). I'm surprised they don't rub a little more than that.
dirtyhandssubaru555
i don't want 14s but that is what came on the car, i would lvoe some 16s
86 gl hatchback rip
87 gl10 rip
86 gl hatchback rip
87 gl10 rip
You're going to have to post pictures of this. There might be some crazy 14s that fit, but can you make absolutely sure they're 14"?
Legacy Central
Which ones?jamal wrote:I'm surprised you can even bolt them to the hub, although it really depends on the wheel. There are 15" rally wheels that will clear WRX 2 or 4-pot brakes.
Folks may want a small wheel for less rotational inertia, which is why I have the stock 15's on my SS although I have 2 sets of 16" (Gold STi V2s, & WRX) rims & a set of 17" rims (ROTA Actions) in the garage. I'm surprised 14's even fit, but they may be tooo small if they are rubbing on the brakes.
15" Rally wheels that fit over 4pots & WRX 2pots are enkei's, & team dynamics. The enkeis are pretty expensive @ 225-250 per 15" rim while the TDs are like 200ish / rim. Just take a look @ rallispec site & they have everything broken down there.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
RC-G4's & ES Gravels will, check the link. Dave is very helpful & will ans any ?s, he says these will fit over 4pots & WRX 2pot brakes.
http://www.rallispec.com/prod_wheel.htm
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
96 Impreza OBS
99 Impreza OBS-T
dirtyhandssubaru555
