Page 1 of 2
I am The Dyno Queen of All BJ's with Over 250,000 miles
Posted: Sun Aug 26, 2007 1:14 am
by siouxbe
This is what you get from a 2.2l N/A SOHC with;
Cobb Equal Length Headers
Hi Flow Cat.
220 grind Delta Cams
Lt. Wt. Exedy Flywheel
Cobb Alloy Crank Pulley
MSD DIS-2
NGK Iridium plugs
JC Sports CAI w/ velocity stack and K & N Pod Filter
JC Sports Torque Chip
Altitude about 5,200 feet
Time about Noon
Temp. about 90 degrees
250,757 miles on odometer
Discuss...
Posted: Sun Aug 26, 2007 1:48 am
by biggreen96
Its not about quantity of HP but of quality... :P torque looks nice and flat.
Posted: Sun Aug 26, 2007 2:14 am
by siouxbe
Thanks Man, coming from you that's a compliment :D
Since I didn't sign up for dyno time with Christian @ Cobb Track Day
I put it on the Dyno here in Boulder to see what it's actually at.
Harvey said it was runnin' rich, so I'll change the Mass Air Flow and see if it improves.
Posted: Sun Aug 26, 2007 2:35 am
by ericem
Is that at the crank? or wheels. You better be running a automatic LOL.
Posted: Sun Aug 26, 2007 2:58 am
by siouxbe
That's @ the Wheels, thank you very much :P
and NO it's not a 'slush-box', it's a manual.
Posted: Sun Aug 26, 2007 3:43 am
by ericem
Then overall thats pretty good. If that was at the crank I would have been angry lol.
Posted: Sun Aug 26, 2007 4:26 am
by biggreen96
I will be so incredibly happy if mine makes it to 250k. I'm sure yours will go forever, looked like you took amazing care of it.
Posted: Sun Aug 26, 2007 5:58 am
by greg donovan
that is on an AWD dyno, right?
Posted: Mon Aug 27, 2007 4:34 am
by siouxbe
Yep, I plan on it :D I purchased this Leggy New the day The Gulf War started. As y'all know it's 130HP @ the Crank stock.
Yes, It's an AWD Dyno.
Compare to another Leggy Wgn. ('93) IIRC put down 62HP @ the wheels on the same Dyno here in Boulder.
Posted: Mon Aug 27, 2007 4:38 am
by siouxbe
Posted: Tue Aug 28, 2007 4:00 pm
by dscoobydoo
strange dip in the middle there on the plot.
Any idea what caused it?
Posted: Tue Aug 28, 2007 4:16 pm
by Matt Monson
dscoobydoo wrote:strange dip in the middle there on the plot.
Most of the modded NA cars do that. Most people attribute it to a hiccup caused by the intake...
Posted: Tue Aug 28, 2007 7:37 pm
by 206er
damn good numbers for an NA 2.2.
is that 250k on the same motor? ever done a compression test on it?
I wonder what mine would do.
Posted: Wed Aug 29, 2007 1:08 am
by ericem
Nice clean car you have siouxbe!
Posted: Wed Aug 29, 2007 9:22 pm
by siouxbe
Thanks Eric, Matt, Hey 206er!
Yep same engine for 250,000 miles
last compression test showed 165psi on All 4 cly.!
Posted: Thu Aug 30, 2007 6:02 am
by 555BCTurbo
Congrats...
Only one thing...
Your car is a BJ, not a BF...
BF = raised roof wagon
BJ= non-raised roof wagon
:D
Posted: Fri Aug 31, 2007 4:26 am
by siouxbe
I stand corrected, I looked it up and yer right.
But, a title of I am the King of all BJ's sounds
so much funnier
Posted: Fri Aug 31, 2007 4:50 am
by DLC
Fixed! ;)
Posted: Fri Aug 31, 2007 3:25 pm
by siouxbe
Thanks Dave, it was good to see you at the Cobb Track Day.
Sorry, I over-heated on the first lap of the 4th session and
wasn't able to give you a ride 'round the track.
Posted: Fri Aug 31, 2007 5:28 pm
by Matt Monson
siouxbe wrote:I stand corrected, I looked it up and yer right.
so much funnier
Um, are you sure about that title? :roll:
Posted: Sat Sep 01, 2007 3:41 pm
by entirelyturbo
Read into it enough, and it becomes REALLY funny! :lol:
All in good fun.
Those dyno numbers are quite impressive. I'd call that stock 2.5RS power, and on an engine with that many miles, that's good!
I'm still very tentatively thinking about doing my car up with an N/A tune once I graduate and the car is no longer my DD.
Posted: Sat Sep 01, 2007 7:07 pm
by greg donovan
i wonder what those numbers would look like if it were just FWD?
Posted: Tue Sep 04, 2007 4:25 pm
by Matt Monson
Actually,
On that particular dyno (which is the same dyno I have used in the past) a stock 2.5RS puts down about 95whp. He's putting down what an RS does with full exhaust on it...
Posted: Wed Sep 05, 2007 8:34 am
by boro
I'm curious what my numbers would be like. I have just under 220k miles with low compression on the front cylinders. I measured the front two at 130~135 psi. The back cyl are at 155-ish.
I run 14psi daily. I'll walk away from a Cobalt SS, from 70mph in 5th. Not saying much, but its a good testament to Subie engineering. I just don't want to blow up on the dyno and be minus a DD.
Posted: Wed Sep 05, 2007 9:03 pm
by starkiller
all righty, where did you get that air deflector ? looks like it might be from a loyale?
