Ghetto 2 level boost controller
Posted: Wed Aug 29, 2007 4:20 pm
Has anyone over here made a ghetto 2 level boost controller?
I made one using a ebay MBC, a DSM boost solenoid (use a charcoal canister purge solenoid), & a switch.
The total cost was under $30.
It was super easy and allows you to run wastegate boost when you want, & MBC level when the switch is activated.
Basically the boost controller vent is blocked by the solenoid when it is in the closed (off) position causing air not to be bled & boost not to pass wastegate levels.
When the solenoid is activated (on) the pressure is released through the vent allowing the MBC boost level to be attained.
You'll have to play with the MBC & restrictors to get to your desired High boost level - just don't over-boost & explode!!!
super simple!
super simple!
