91 legacy SS part out.....
Posted: Fri Aug 31, 2007 9:08 am
by douglas vincent
Everything is available off of it, EXCEPT motor, front fenders, front bumper
All pricing is PLUS SHIPPING!
Tranny is 5mt $600 obo for the moment
Radiator and remote filler $140
Front and rear brakes, calipers, rotors, and mounts, $125 (worth it!)
Brake booster $40
ECU $75
Rear LSD $100
Motor will be available after rebuild with new Wisecos, ACL race bearings....
The rest of the bits are available, just ask.....
Posted: Fri Aug 31, 2007 5:55 pm
by skid542
Dibs on LSD!!
It is stock 3.90 correct? Can I get it with the axles as well?
What are you doing with the clutch pedal assy?
Posted: Fri Aug 31, 2007 7:07 pm
by douglas vincent
Yes it will come with the axles, whole assembly, However, I may have to cut the trailing arms to get it off easy, let me know if thats a problem.
Pedal assembly available.
Posted: Fri Aug 31, 2007 10:37 pm
by baddriver
What color is the car?
Posted: Fri Aug 31, 2007 11:09 pm
by skid542
Doug, when you say cut the trailing arms off, you mean off the car's suspension? I have a good working open diff and rear end and really just need the LSD diff and the axles so that I can drop the current one down and pull the axles and put the new one in with the axles. I have gotten underneath my SS and really looked at the rear end but I assume it's like my OBW where the diff attaches with a few studs?
Either way, I'd love to take the diff and axles off your hands and I can make it work when it gets to me.
How much for the pedal assy?
The trunk latching mechanism, is it the same between pre and post-facelift? If so I'm also in need of the latching mechanism in the trunk and the bar attachment that is attached to the car. Mine is worn so much that my cable won't actuate it anymore. You interested in pulling this for me?
Thanks.
Posted: Sat Sep 01, 2007 1:44 am
by dwreck30
Lee, are you talking about the axle stubs coming out of the diff? You need those, but you don't need the the whole axle to swap diffs. Didn't know if you knew or not.
Posted: Sat Sep 01, 2007 1:52 am
by skid542
Stubs being just the part of the axle that goes into the diff and to the first CV joint?
Guess I need to do some more reading up on all of this.
Either way, just send me what I need and I'll sort it out when it gets here
Posted: Sat Sep 01, 2007 1:54 am
by dwreck30
Yes. Just trying to save you some shipping costs.
Posted: Sat Sep 01, 2007 2:51 am
by skid542
I appreciate it Derek. Thank you.
Posted: Sat Sep 01, 2007 5:27 am
by starkiller
adjustable headrests?
Posted: Sat Sep 01, 2007 5:37 am
by smh0101
Did it have fog lights?
If so do you have the panel that the switch attaches to?
