Head Swap question
Posted: Tue Sep 18, 2007 6:59 pm
by czaplicki
I have a 2.2T (EJ22T) Legacy engine. I would like to rebuild it for rally. I want to get more power out of it. I would like to change the heads to 2.5 heads (NA EJ25), do pistons, cams, etc. Does anyone know what heads I can run (what years, phase, and head gasket?). Any brand on pistons, and cams? Anything would help!
Posted: Tue Sep 18, 2007 8:23 pm
by Arctic Assassian
Search. search. search... sear............CH! look two threads up! search for freaking head swap! There are so many answers on the first two pages of this forum its not even funny.
Posted: Tue Sep 18, 2007 9:45 pm
by dropdfocus
Yes, please use the search function that the forum offers. I will offer this link as assistance for you since my motor has the swap done:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
Posted: Fri Nov 16, 2007 9:08 am
by Dantes Inferno
Since youve done the swap. What did you do about the larger diameter of the 2.5 head vs the 2.2 block?
And what did you do about the oil line not mating from the 2.2 block to the 2.5 manifold?
Posted: Fri Nov 16, 2007 9:26 pm
by Arctic Assassian
You have to drill and tap a new fittting for the oil line, and always use the gasket that corresponds to the head. It is a HEADgasket.
Posted: Fri Nov 16, 2007 9:55 pm
by dropdfocus
Or you can use the oil filter sandwich. That's what I'm using and a few other people w/ Imprezas have done the same & it works just fine.
Posted: Fri Nov 16, 2007 10:25 pm
by Arctic Assassian
whats the oil filter sandwich?
Posted: Fri Nov 16, 2007 10:37 pm
by dropdfocus
Posted: Sat Nov 17, 2007 9:18 am
by BB
If you've got a caged car, you're probably running p4, but swapping heads would put you head to head with open class cars right?
Yeah headswap can net some serious gains, but its not for the faint of heart.
