Mechanical FCD - it works!!
Posted: Thu Sep 27, 2007 12:05 am
My quest for a fuel cut free car has finally come to pass
To start I acquired a VRG FCD, but after installing this I still had fuel cut at 13-14psi. I attribute this to the 5500ft of altitude I live at, as I learned that the ECU recalculates the Fuel cut psi from "base" atmosphere and goes from there. Others at altitude have had similar isssues with this unit. So the VRG came out, no big deal - it was cheap.
Then I was reading about all the bleed valves, small holes, MBC, etc... ways of fooling the MAP. These work, but I want the MAP sensor to see boost - just not over the threshold of fuel cut (I guess the MBC method would do this too, but I wanted a set-it and forget-it option)
Enter McMaster-Carr (www.mcmaster.com) . I'm an engineer so I deal with McMaster frequently and know they have unimaginable amounts of weird devices/components available off-the-shelf. What I found was a pressure relief valve that has a set pressure that it releases at.
I ordered the 10psi version, PN 4320T13 ($27). It is a push-in style miniature valve with 1/4 ID inlets. (you can get all kinds of release pressures, from 0.5psi-10psi)
I fitted this into the line between the solenoid and the MAP using push in plugs, like PN 5111K504, and some 8mm ID tubing I had to bridge the gap (wire tied to create a good seal).
I drilled out the plug on the inlet side with a 0.050" bit to provide some decoupling from the rest of the system, and slow the flow to the valve so it could keep up with the pressure increase. The other side (from the valve to the MAP) I drilled out to a 3/16" or so.
The result is a fuel cut free 14psi of boost. I ramp boost in 5th gear at 3000rpm and stand on it - No cut up to 100mph.
I'll get some pics up, but it is really easy to do and cheap (cheaper than an HKS electronic or something - and I like mechanical things anyway)
-Chad
(edited for correct ID on tubing)
11-1 EDIT -> I DID get fuel cut this AM. It was hanging around 32F, and my boost was up a bit due to the cold air. I hit just about 15psi in 3rd gear from about 3000rpm - and hit fuel cut just as I was about to lift off. It probably made it past 3sec, but.... I think the little valve just can't flow much. I'll be trying a smaller hole in the inlet plug - maybe more like .030" (or a 1/32, close enough at .0312"); if that doesn't fix it, then I'll go to a #75 (.021").
-Chad
