coolant surge tank needed bad! real bad
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
so i looked at my surge tank the wrong way and bam it broke it self, well kind of. so any body got one ill take it. a wrx one would be even better
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
smh0101
Post by smh0101 »
Here is a tip...
Pull the P.O.S out then tap out all of the nipples... Run to Ace Hardware in another vehicle with the tank and buy some brass nipples and JB Weld and re-do the nipples on the tank... GO REALLY HEAVY ON THE JB WELD! Then let it sit for as long as possible at least over night and then wah-la! Go ahead and re-install it and your good to go.
They wont break any more.
dirtyhandssubaru555
already did that with a peice of copper pipe and quick steel, jb weld was not intended to with stand heat. jb has never worked on any thing that got hot for me. i may try some stuff call plastic steel. home depot is a 5 minute walk(kind of a bad thing since i love power tools$$$$$$$)
86 gl hatchback rip
87 gl10 rip
smh0101
Post by smh0101 »
Hmm thats interesting... Mine has worked fine. Maybe a different type of JB?
