Quickest BC Legacy (1/4 mile) the US?
Posted: Fri Oct 05, 2007 8:21 pm
by BXSS
What is the quickest 1/4 mile time recorded on a BC leggy in the US?
I think the quickest claim I have seen is Douglas Vincents' twin-charged Red wagon @ mid-high 12's.
Anyone heard of or saw something quicker?
Posted: Sat Oct 06, 2007 4:02 am
by douglas vincent
Here is some other info/thread on fast legacies, not much info though..
http://forums.nasioc.com/forums/showthread.php?t=482898
Posted: Sun Oct 07, 2007 11:01 pm
by BXSS
Looks like the Twin-charged wagon is possibly one of the quickest if not the quickest BC Legacy in the US.
HP - 1/4mile calculators do not count, as there is more to good times than HP.
Our 9.97 second Budget car was stuck @ 11.31/124MPH (12psi) & according to the calculators we had the power to run 10.99 @ 10psi, but increasing boost just led to more wheelspin & slower times.
Changing Final drive gear ratios dropped times from 11.31 - 10.4 both @ 124 MPH everything else down to the program in the ECU was the same.
Posted: Mon Oct 08, 2007 3:13 am
by douglas vincent
I know I am not the fastest BC in the US, but until someone has proof, I claim it! haha.
There is a 2.0 1992 Liberty RS in Australia that did a 10.9 @ 127 last year....
I keep trying to get some fast older legacies out to the strip but they always pass....
Posted: Mon Oct 08, 2007 4:34 am
by evolutionmovement
BXSS, did you run a higher (lower numerically) ratio to reduce wheelspin? I know what the numbers are telling me for the vehicle I'm designing, but am wondering about the ratios I'll end up with (2.0 S2000 with 2.83 or 3.09 FD). I have about half the weight of the donor car, but a much higher ratio, but also only 1 wheel to put it down with. I'm thinking it will all work out (absolute worse case of 6.5 lbs/hp), but first is still pretty high and I need a largish wheel for ground clearance and visual balance.
Posted: Mon Oct 08, 2007 1:40 pm
by BXSS
Yes the FD# was lower.
Are you doing a S2000 - AE86 swap or something crazy?
The car I was talking about is an OLD School PR Drag car, that weighs 2001lbs (Lighter is better). The gear ratio was made taller (smaller #) & with that change the car was able to run 1+ seconds quicker.
The power to weight ratio is about 4.7-5.0#/HP.
All is not done yet as I feel we may need bigger tires or a taller gear ratio to max the current set-up out - 60's @ 15PSI = 1.3x, but 60' @ 20psi = 1.5x (there is some slip on high power launches).
Here is the car
http://bbs.legacycentral.org/viewtopic.php?t=32633
The Leggy from NZ does not count as it is not in the US & is not a BC (if it is the green one I'm thinking about) - TRP's gold BC runs 10's, but is in Australia.
Posted: Mon Oct 08, 2007 11:29 pm
by 206er
jake's dads wagon has got to be pretty damn quick. what's it run jake?
a few years back i heard rumors of a V. 8 BC being built here in CO but have not heard or seen it since.
Posted: Tue Oct 09, 2007 12:23 am
by 555BCTurbo
206er wrote:jake's dads wagon has got to be pretty damn quick. what's it run jake?
He sold it :(
I rode in it...and I'd say 13.7 ish
Posted: Mon Oct 22, 2007 2:09 pm
by BXSS
Douglas Vincent / Reddevil = BC Legacy 1/4 mile king @12.5's.
