FOUND THAT #@$&!@# Sound
Posted: Thu Oct 18, 2007 8:52 pm
by Carbix
bah for a year now i have had this tisking sound coming from my glove box area at about -10psi but really its righ off the air intak all and be hold its the damn Air Bypass Valve :evil: damn little plastic part.
Posted: Fri Oct 19, 2007 11:54 pm
by Arctic Assassian
congrats, I hate all the little noises that come with owning a 17 year old car.
Posted: Mon Oct 22, 2007 5:55 pm
Is it normal, or was something broken?
Posted: Tue Oct 23, 2007 3:41 am
by Dynamic Entry
Ya ya, was it broken?!
Above 7-8 psi I have a "tisking" sound too. Like air is getting chopped up and not flowing smoothely or something.
I admit that it might be my pod filter....... :(
Posted: Wed Oct 31, 2007 2:44 am
by subytech
Had the exact same noise and it drove me nuts for the last year. Then my friend told me one day he herd a similer sound comming from my exhaust when I drove away, turned out it was the wastegate solonoid taking a crap and opening and closing the wastegate very rapidly at around 5-10 psi. I just installed a Turbosmart MBC and vuala no more nose and steady boost all the way to 10 PSI. Easy way to figure this out is to re-route your vacuum lines so that the solinoid is still geting a boost signal but isn't connected to your WG then just run the wastegate off manifold pressure. You'll only run WG pressure but if the noise is gone your solinoid is the problem. The tisking noise is a combination of boost leaking out through the wastegate and the wastegate itself opening and then slamming closed against the turbine housing.
